I saw the writing on the wall. Windows had been installed for quite some time and I kept looking at the jambs saying how am I supposed to deal with this?
While other projects were ongoing it finally hitme.
Wood Ceiling Window Room Plywood
I had window jambs that were 1/4-1/2 inch out of plumb. By removing the extension jamb and cutting my metal security strap I was able to pull the jamb in to position w a bar clamp. Now this is a new house and the walls/openings are square. It's just that the window install was done to quickly without attention to detail. None of this was noticed until drywall was installed.
I used scrap wood to protect the window frame and the finished plaster and paint.
After sucking it in I was able to install window trim with ease.
Window Property Room Wall Sash window
Super Moderator
That's an old finish carpenter's trick. Old timer showed me that awhile back. Works we'll in most cases. If not, I take a small block plane and hand plane the jamb extensions when they're in place.
Mike Hawkins;)
If the extension jambs stick into the room, they can be planed off with a hand or power plane or with a router and modified base. For extension jambs that are too small, pulling the window in works sometimes. Gluing on a strip to the extension jambs may work, also. I have done both. Sometimes it is the sheetrocker's fault, where they do not use enough screws. I have added screws to pull in the sheetrock and I have shaved off a layer of sheetrock in other cases.
The extension jamb battle is always the nightmare for trim carpenters.
