Made four end grain boards out of hard maple and purple hart. I set them outside in the sun today for about 5 hours and when I went to bring them in they were all warped :sad:
How thick are they? If it's not too bad, you might be able to drum sand them flat (maybe use a friends or a shop's if you don't have one). Also, perhaps you could sandwich them between to flat surfaces and very gently put slight pressure on them over several days with a little steam or moisture.
Instead of putting water on the wood, I've had very good results with setting warped panels on a lawn. With the sun on one side and the humidity from the grass on the other side it should come flat again. I'll often put cherry outside to 'suntan' before I finish it. If it's a loose panel I'll be sure to have it stickered well and then flip it regularly. Good luck.
A forum community dedicated to professional woodworkers and enthusiasts. Come join the discussion about shop safety, wood, carpentry, lumber, finishing, tools, machinery, woodworking related topics, styles, scales, reviews, accessories, classifieds, and more!
