I located the fence so the saw blade will be safely behind it when sliding a 1 1/2" thick piece along the fence for a cross cut. It is just screwed to the top, no dado, so I can move it if needed. It's actually an "L" shaped assembly of 2 pieces. I used 1 1/2" angle along the front and back of the base to support the added length to the left. I really like this system and use it fro almost all my 90 degree crosscuts. I use a 60 tooth thin kerf Freud Diablo blade designed for miter and radial saws with negative or low angle hook to the teeth.How far is the fence from the back? Did you dado the top to accept the fence or is it just screwed in from above?
