1 - 20 of 36 Posts
havin fun gettin it done
Hi Everyone
A few of you have expressed interest in seeing how I create the small Intarsia that I do on the tops of my boxes.This project will not be too extreme but will give you a good idea of how I work with cutting, shaping and fitting some of the tiny pieces that I work with.
This is an anniversary gift box and will allow me to use a couple of new techniques that I have been wanting to try out.
I will begin by showing the subject photo supplied by my client to use as the Intarsia on the top of the box.
Toy Stuffed toy Teddy bear Fur Plush
Stay Tuned -- The fun has just begun
I'm in watching :laughing::laughing::laughing: I need to learn this one, Dom don't let Mike next to the popcorn he will eat your hand to
Discussion Starter · #9 ·
The Box
Before I do any Intarsia for this project I first have to make the box. I chose a beautiful piece of 4/4 cherry, jointed one edge and ripped it down to the approximate width.(3 1/8")
Wood Plywood Hardwood Lumber Floor
Wood Table Hardwood Plywood Lumber
Back to the jointer to flatten one side and resaw to approximate thickness (9/16")
Machine tool Machine Tool Wood Tool accessory
Next step is at the planer where I take the stock down to final dimensions.( 3" wide x 1/2 " thick
Machine tool Wood Machine Tool accessory Tool
Wood Finger Plywood Ruler Table
continued
The Glue-Up
The next step in the box construction is routing all of the grooves for the upper and lower backer boards and the accent strips. I use a 1/4" straight router bit set at 1/4" deep. The upper backer is down 1/4" from the top and the bottom backer is set 1/8" from the bottom. The accent strip groove is routed 1/8" deep and 1" from the bottom.The walnut inlays are now glued into to each section of the box sides with ca glue then trimmed flush with the miters using a small back saw. Accents are sanded flush with the box sides. At this point I do the final sanding on the insides of the box sections with 220 grit paper. Because I will be sawing the lid after the glue-up is done, I make some reference marks on the miters 3/4" down from the top. This is so I won't drill any holes in this area that will show up after the lid cut is made. Using a 5/64" high speed cutter on my rotary tool, I drill a series of shallow holes into the miters that will allow glue to strengthen the miters.Time for the glue-up. Clamping a straight edge to the workbench, I lay the sequentially cut box sides groove down and pull the pieces together with 2" packing tape keeping the edges against the straight edge.
Wood Floor Hardwood Plywood Flooring
I flip the whole assembly over and apply glue to all of the miters and backer grooves, insert the backers (1/4" oak plywood) and pull the sections together securing the last corner tightly with packing tape. Square up the box if needed. More packing tape is used on each corner stretched tight diagonally to pull the corners tight.
Wood Plywood Floor Hardwood Wood stain
Wood Plywood Box
Glue up is done. Next step is cutting the lid.
Stay tuned
Discussion Starter · #12 ·
Separating the lid
This step is pretty straightforward but having the bandsaw set at exactly 90 degrees is very important .
I went ahead and did the round overs on the top and bottom edges of the box using a 1/4" round-over bit set up on the router table. I also did all of the sanding to the box sides up to 220 grit.The band saw is set 3/4" from the fence and just high enough to clear the box.
Machine Machine tool Wood Tool Wood shaper
Wood Table Hardwood Lumber Furniture
Now it's just a matter of slowly feeding the box through the blade to make the cut.To get rid of the saw marks, I start off with 60 grip sandpaper on a flat surface and using a circular motion, sand until the saw marks are gone , then proceed with 100 grit , then 220 grit. This assures that both surfaces are nice and flat.
Wood Box Hardwood Plywood Rectangle
Separated Lid
Wood Product Furniture Table Hardwood
Next step-- Morticing the hinges
Discussion Starter · #13 ·
The final step in the construction of the box is installing the hinges. For this job I have put together a little jig which makes it much easier to accurately do the small mortices required for this type on hinge.These hinges are 1" x 1" brass and require a mortice which is 1/16" deep on both sections of the box.I had an old dremel tool that no longer worked with the variable speed, combined with the cheap dremel router base that I didn't use for anything . With the addition of an 1/8" high speed cutter I now have a dedicated hinge morticer. I begin by measuring 1" from the corners of the back of the box and mark with an exacto knife. Place the hinge on the mark and mark the opposite edge of each hinge. The jig now clamps on the reference mark and routed . Move the jig over for the other hinge and route. A sharp chisel removes the little bit of waste in the corners to square up the mortice. Repeat this procedure for the lid of the box.
Accuracy is the key to getting this right so everything lines up. I will actually install the screws when the box is just about finished.
Wood Workbench Table Tool Hardwood
Table Workbench
Wood Drawer Hardwood Table Plywood
Box Chest Furniture Trunk Wood
Let's do some Intarsia
Discussion Starter · #17 ·
The Pattern
Here are the steps I use to create the pattern for the Intarsia.
I start by printing a color copy of the subject photo to 8" x 10". Using carbon paper and a # 7 mechanical pencil I trace all of the outlines and details onto a sheet of paper.
Shih tzu Dog Canidae Toy Companion dog
Drawing Sketch Line art Teddy bear Artwork
The inside dimensions of the box lid are 5" x 6" so using Word, I create a rectangle with those measurements. The oval is done using the same process with the dimensions of 4" x 5" which will allow 1/2" on the sides of the background. I cut and paste the oval into the rectangle. At this point I make a few trial and error copies of the subject reducing it until it fits into the oval. Cut and paste into position. A little hand drawing to bring all of the lines to the edges of the oval and I now have a pattern. Simple but effective.
Drawing Sketch Line art Visual arts Artwork
Next step-- A Little Intarsia
Looking purity sweet I'm liking it :thumbsup::thumbsup::thumbsup:
Wow, I have made several cigar humidors using the same technique of building a box and cutting it in two but I never would have considered using my bandsaw for the job. Personally I would have been concerned that the blade might walk or not be perfectly square with the table. I have always used my table saw and cut one side at a time. After each cut I secure the cut with a piece of 1/8" plywood and some carpet tape. That way when you cut the final side the lid doesn't fall over or get caught between the blade and the fence. Beautiful work. I can't wait to see the finished product.
1 - 20 of 36 Posts
