Newbie here trying crown molding for first time. Bought Dewalt DW716 with crown stops.
First corner - took two minutes, little need for caulk, pretty proud of myself.
Second corner on - disaster.
Wall dips in near the ceiling at the corner for one side and not the other. Tried coping but still couldn't get it close? Maybe I am coping wrong or taking the wrong approach so instead of trying to explain what I am doing can someone just tell me what I SHOULD be doing at these corners? (I had to pull the molding away from the wall 3/4" to make the corner fit. so I know there is a better way).
At another corner the ceiling rises up and I have to put in shims to make it match the other corner. (That I don't mind as much because I can hide it)
Just beggin for advice from people that know what they are doing. Searching the web did not help because my walls aren't square and there wasn't enough enough on what to do when they aren't 90 degrees. I think I need to at least buy something to measure the angle of the wall I assume?
Any help is appreciated............
