I am putting up angled crown molding on my new cabinets. I have most of it done, but
I have come to a weird angle that I just can't figure out. The two cabinets form a 170 degree angle and with angled molding I have tried several different angles, but none work. Anyone tackled something like this before. Any help would be greatly appreciated.
A little sketch of how you are measuring the angle would help me at least.
I think it is probably an 80 degree angle. I think you need to subtract 90 from 170 and that is the angle so the miter would be 40 degrees.
170 degrees?
That's within 10 degrees of a straight line...180 degrees. Are you sure that's the angle?
Are you interested in the answers and questions to the thread you posted?
Are you there? :blink:
bzguy
It's a compound angle determined by the "spring" angle on the crown itself.
If the crown is narrow enough you can hold the flat piece at the bottom that actually touches the cabinet against the miter saw fence and cut at 5 degrees.
