1 - 9 of 9 Posts
I have been working on a wooden gear clockand I made a mistake. In the center of one of the gears there is a .250 dowel hole that I somehow drilled crooked. Not sure what I did but it happened and now the gear wobbles pretty bad. I have looked online for a sleeve or bushing of some type, but have not been able to find anything. I was hoping someone would have an idea to help me fix this.
One thought I had was to use wood filler and re-drill it, but I wasn't sure if there was a better way to go about it.
Thanks in advance for any help you can provide.
Log dog
I would make a plug out of the same wood and the same size, then glue it in and let dry. Then re drill hole.
Got any pics?
I would plug it as well. But if its in a spot that would not be seen, another option would be automotive bondo. Putty will crack as it dries.
The woodwrongs shoppe
drill it out as big as you can and plug that...then redrill the smaller hole
use a diff color wood for the plug and it will look like a part of the design
I really appreciate the advice. If nothing else this will give me an excuse to purchase a plug cutter.
:thumbsup::thumbsup: New Tool LOL I need to remember this one
If it's not to be seen glue a dowel in it then cut it off. Allow to dry then redrill straight this time.
1 - 9 of 9 Posts
