Hi, I bought a used craftsman tablesaw model number 113.298840. I had to adjust the trunion because my blade was not parallel to the miter guage. After I did that the belt was very loose on the pulleys. I bought a new belt and adjusted the motor according to the manual. I tested it by pinching the belt and the motor moves freely. But now the belt has a pretty bad wobble. The blade isn't wobbling from what I can tell. Any suggestions?
I'm thinking of taking off the pulleys and seeing if those look bad and maybe cleaning the shafts. Thank you in advance!
No, leave the pulleys on so you can rotate them and observe if they are the cause of the wobble.
A belt won't wobble unless the pulleys are bent or not seated on the shaft properly.
A belt that has been wrapped in a circle for a long time will take a set, so that may be the cause?
A link belt is the least likely to vibrate or wobble.
Hi, thank you! It's a new belt that's on there, same 4L420 V belt that it came with. I'll take that belt off and look at the pulleys. I'll also buy a link belt and try that out. I appreciate the response.
Good luck
The few I have worked on it’s easy to move in the tablesaw the aluminum pulley to get bent / damaged. That is a common one that Emerson used. …about $8.00 for the same one.
