My craftsman table saw original motor (1/3 hp @ 3450 RPM) is losing power. Cutting through a 2x4 slows the motor down considerably even with new blades. I was given a 3 hp Baldor motor (1725 rpm). The balder is set up with a 110 electrical plug in so it would be a simple wire in to the switch.
Do I need to change the pully on the motor to achieve the higher RPM that the saw had originally? What mods would you recommend for using this motor or, would I be better off to scrap the idea of using the gifted motor and find another to match the original?
