Sawdust Creator
So....I was in need of a drill guide to peg the legs into the apron of my coffee table. I couldn't get the drill press in where it needed to go.....and it needed to be 90 degrees and no movement to ensure a round hole.
The craftsman drill guide failed on all grounds. the holes ended up not 90.....there's a ton of play in the guide...enough that the tip of the bit moves in a 1/4 inch circle.
Now I have alot of craftsman tools.....tools from under a buck.....to over a grand.
However.....this one is a big fat zero.....so much so...its going back and i'll find a different one to pin the last two legs.
I have had little luck with this type of jig as well. Here is an alternative:
Buy a flange (plumbing department Home Depot, for example). You can use 3/8", 1/2" pipe, 3/4" or 1" depending on your desired hole size. Get a nipple to fit in. In mine I use pvc fittings and or pipe in the ends of the pipe to vary the size.
This is one I did for drilling a set of 3/4" holes in a bridge. The pipe size is these is 1". These holes went through up to five 4x12 pieces of wood.
Another way is to drill a thick block in your drill press and use it as a guide. Start the hole in your piece to center it, put in your long drill bit, slide the block down in place and drill.
That craftsman drill guide I believe was originally a Portalign guide. Sears may have had them make a version for them. My Portalign drill guide worked fine with an ancient B&D electric drill and was so useful I just kept it on that drill until the drill died. Mine never had springs on it, and the one thing I remember is that I had to keep one hand on the base to make sure it didn't tip while the other hand held the drill trigger and pushed down.
Sawdust Creator
The concept was sound, but there was too much play in the carriage. I could move the tip of the bit roughly 1/4 inch in any direction. I thought of using the thick block idea, but I was trying to use a forestner bit. I may in the future start the hole freehand with the forestner bit and then switch to the block/twist bit combo to finish the hole.
