I'm building shelves with some reclaimed wood. The "design" is very simple. See the photo, which is a quick setup of the cut wood. I will align things better in the end. They are 11"x3" Douglas Fir Joists. The issue I'm worried about is how to get these levels to be balanced and straight. There will be 5 of the horizontal planks and four of the verticals between them.
So if there are some vertical planks that were cut slightly off (angle), how can I correct it or make up for that missing space? Especially if it's very slight? Is there a trick? Use a wedge? Thing about a wedge, they're usually too thick. Also might be too soft??? Any ideas would be much appreciated.
The next issue is how to fasten these together. I was thinking either a T or L or I shaped plate fastened with screws, behind the shelf? What do you think?
Thanks in advance for any input of finishing these shelves.
