Enough of this nonsense, I need a board 3 1/8" wide, I set the fence moving the pointer to land on 3 1/8", I switch on the saw and power feed then watch the board run through the saw, does this mean I am not really a woodworker?
If you're only reason for cutting the board 3 1/8" wide was to have a board 3 1/8" wide, then no, you're not a woodworker. Anyone can make an accurate cut on a table saw if it actually does all the work except initial set up. If you give that perfectly cut 3 1/8" board to a CNC operator, and they put it in a programmed machine that cuts a sign into it, they aren't woodworking either.
The CNC operator then hands it to a person who cleans up the sign, sands it and then finishes it ... THAT guy is probably a woodworker.
I believe, when you prep a piece of wood for the machine, you're working the wood. When you finish the CNC cut piece, you're woodworking. The detailed work the CNC machine did ... you don't get credit for as a woodworker. You get credit for it as a computer programmer, but not for the wood work.
Putting an IKEA cabinet together doesn't make you a cabinet maker. Putting the finishing touches on a CNC made sign doesn't make you a sign carver.
