You should be able to turn bowls with just about any chuck. Most come with 50mm jaws to start and you can buy other jaw sets as your needs arise.Any suggestions on what type chuck would be a good beginner type chuck. Also what type chuck would I need to turn bowls?
Jim
FYI on the jaws. Each set of jaws has a limited range of expansion. The manufacturer will state the range. Not as much as you may think.You should be able to turn bowls with just about any chuck. Most come with 50mm jaws to start and you can buy other jaw sets as your needs arise.
Check your post about this:I just purchase a delta 46-525 I don't know how old it is but it is brand new never been used, I would like to know if anybody knows of a drill chuck that will fit the tail stock so I can bore out my projects?
