As duncsuss stated, what are you desires for turning projects?
You have the HF 12x33 lathe.
If you wanted to turn e.g., a 12in bowl, this is a decent size. When you start out it will not be balanced, and takes a lot of holding power.
My friend has the same lathe as mine, a NOVA DVR XP 1624. He started out with a NOVA G3, then started turning larger bowls. He has only gone to about 12in bowl. He eventually purchased a SuperNOVA 2 chuch since it was beefier and slightly larger diameter. Much better to hold the out of balance large bowls with his #3 jaws.
I have Oneway Talon chucks.
Next question after which chuck is what sizes of jaws and whether smooth, dovetail or serrated. No black and white answer. For smaller items it may not matter. For large bowls, I have read dovetail jaws grip better than serrated.
