1 - 9 of 9 Posts
Am going to be building a small mill it is going to have a 16 inch saw does anyone have plans for one
Senior Something
I am no expert, but 16" sounds a little samll for a CSM. You might want to think about something like this:
http://www.baileysonline.com/Forest...-Sawmills/Micro-Mills/Accutech-Micro-Mill.axd
Harbor Freight used to sell a knock off for a lot less (<$40) but I could not seem to find it. I have one that I occasionly use on a 20" bar and it does ok, but you have to be careful to keep it on track on the guide board.
Found this, but still more expensive than the HF model. Identical.
Haddon Lumbermaker - Amazon.com
djg said:
I am no expert, but 16" sounds a little samll for a CSM. You might want to think about something like this: http://www.baileysonline.com/Forestry-Woodcutting/Portable-Sawmills/Micro-Mills/Accutech-Micro-Mill.axd Harbor Freight used to sell a knock off for a lot less (<$40) but I could not seem to find it. I have one that I occasionly use on a 20" bar and it does ok, but you have to be careful to keep it on track on the guide board. Found this, but still more expensive than the HF model. Identical. Video Link: http://www.amazon.com/Haddon-Lumbermaker/dp/B009L6CJXA/ref=sr_1_2?ie=UTF8&qid=1387676809&sr=8-2&keywords=lumber+maker
I am going to be building one not buying one
Senior Something
I wasn't trying to sway you into buying one, I just thought it might be easier. When I think of a CSM, I first think of a Alaskan type mill first. I didn't think something like that would be applicable for a 16" bar. So I simply offered examples for smaller type mills. As I said, I'm no expert. Good luck and let us know what you come up with.
I will it should be fun to make for it only being 150 bucks
My father has 441 chainsaw with a 18",25", and 32" bar. He uses his 18" to fall trees and his 25" to mill. He has both a regular chainsaw mill and the mini mill... I could ask him for dimensions if that would help with your build.
That would help thank you
Doh,
Totally spaced it... Was having way too much fun! :)
I work with the old man, so I will get with him after he gets back from vacation and get you that info.
1 - 9 of 9 Posts
