1 - 20 of 44 Posts
· Super Moderator
The name came from the fact the accounting firm wanted their entryway to look like a castle door. It's an internal door inside a commercial building. This is the picture they gave me
Brown Property Door Building Fixture
I had to size it to fit the area of course, but I kept the relative proportions the same. I drew it up in AutoCAD, which I had to learn because my DOS based CAD didn't do dimensions for curves well.
First thing I made was the door. The CAD is my DOS based version
I'm starting to make this. Quartersawn Red Oak for the door and plain slice for the frame and windows. They want it stained a honey oak or similar. I've made samples but it doesn't do the quartersawn justice. Needs to be darker and it'll stick out nice. I'm starting to make this. Quartersawn Red Oak for the door and plain slice for the frame and windows. They want it stained a honey oak or similar. I've made samples but it doesn't do the quartersawn justice. Needs to be darker and it'll stick out nice.
Rectangle Parallel Font Pattern Drawing
Got most of the door stiles/rails made. Just have to deal with the curve on the top rail now.
Top of the door radius is 54 13/32". That way after the 3/32" gap on top everything else above it will be an even number radius.
Wood Automotive design Flooring Hardwood Lumber
Got the curve drawn out. Now I have to make the template out of particleboard to make the curve on the shaper. Big cut so I'll likely do it in 3 passes.
Wood Wood stain Hardwood Composite material Plank
· Super Moderator
Discussion Starter · #2 ·
Made the jig to hold the top rail that has the curved pattern on it. Removed the fence on the shaper and installed the rub bearing. I did it with a top pattern so I didn't need to adjust the height of the cutter, so that cuts down on some setup time.
And then it looks like this.
Wood Composite material Hardwood Wood stain Building material
Wood Gas Machine Composite material Plywood
· Super Moderator
I planned on showing the full pass but I spaced out. This is the 2nd pass after taking the bulk of the material on the 1st pass. I rough cut the curve, put it on the template and then do the rough pass. It follows the cut panel because the bearing isn't low enough. After I do the rough pass I use a small router with a pattern bit on it and trim the 1/4" thick tongue to the curved pattern and then run the panel again. It's better this way because my final pass I'm only taking about 1/16" of meat and I have no real chance or burning because I'm going to slow because of the load on the shaper. Only a 3HP shaper and this bit is close to the max I can use when taking a single pass.
· Super Moderator
Got the door in clamps. Sprayed the backs of the panels to seal them. Put tape on the corners so I could put a spot of glue and then glued the panels back to back. I put stain on the tongues of the panels so when they move with seasons you don't see a light line.
In clamps.
Wood Floor Flooring Rectangle Gas
And then out of clamps.
Wood Door Rectangle Flooring Floor
Still need to cut the curve on the top of the door.
· Super Moderator
Worked on 2 of the curved headers. Cut some Oak and Poplar flitches about 1/8" thick and 3 7/8" wide and went to my buddies with the widebelt and sanded them down to a little under 3/32". 8 of them made just under 3/4". Have to account for glue thickness.
He made me these templates on the CNC. I joined the 2 of them together with the Poplar spacers to make them 3 7/8" wide.
Building Naval architecture Wood Urban design Composite material
After some testing I decided to put some slots in them near the ends for clamps.
This one has a header that I glued up and will stay on the form overnight for the glue to get rigid. I needed the clamps for the next one.
Wood Composite material Fish Engineering Metal
Here we are fully clamped up. This one has the Oak on the top of the curve because it's the curved base for the upper curved window.
Wood Art Event Metal Collection
· Super Moderator
Did the scary part. Cut the curved top as a unit. It's only held by clamps so far because I need to be able to access the interior when I put the angled supports that surround the top curved window. Took me 45 minutes to gain the courage to make the cut. If I screwed it up 12 hours of work would be down the drain.
Here's the 1st cut. I did that and went home LOL. No, I'm not kidding. Dinner was ready.
Saw Cold saw Abrasive saw Wood Gas
I did the second cut, had a lot more confidence. Still had to take a trim off of it after I did a test on the door. I need 3/32" on either side and one was a bit more than an 1/8".
Then I made the parts for the straight boxes. And put the 35º angle on them, put a biscuit in the joint and then screwed them together since no one was going to see it anyway. Cut the 35º miter on the trim part of the box and wa-la
Window Wood Rectangle Flooring Hardwood
Here's the curved to straight miter joint. Just pushed together, no glue or clamps.
Wood Window Building Wood stain Floor
The black spot is where the sawblade washer rubbed because it's right at the limit of my saw. It'll sand out.
· Super Moderator
Screws screws and more screws
Wood Automotive exterior Composite material Engineering Automotive wheel system
Clamps clamps and more clamps.
Wood Hardwood Engineering Event Shotgun
Should be the last laminated curve for this project. Next comes the curved trim. That's segmented.
· Super Moderator
Made the angled blank into a nice curve.
Wood Rectangle Table Flooring Wood stain
Fits nicely on the bent lamination. The lamination had some spring back. More than the other two. Not sure why. I usually have great luck with the thinner laminations. That won't matter much when the solid curve is glued to it. Won't be going anywhere.
Wood Automotive exterior Composite material Font Hardwood
· Super Moderator
Discussion Starter · #10 ·
I cleaned those two benches so I could start assembling the surround for the door. Jamb is 4 7/8" wide along with the curved header. Instead of using miters I did a butt joint which seemed easier because I don't have to cut a miter on the curve. Took a while to dial the miter on the straight jamb. Mostly because I didn't realize how crooked I had the parts. That's what that center board is. The two ends are square, the length is what the opening is. I measured down from the miter and put a mark on the jamb and did the same on the other. I was off by about 3". After I clamped the board in things went much smoother with a squared up unit.
Wood Table saws Gas Machine Engineering
Multiple hours later I had the jambs screwed together and the miters on the curve and straight trim cut and pocket screwed together.
Wood Automotive design Floor Flooring Engineering
And here's the top curve
Property Wood Architecture Interior design Floor
And the two miters which came out very nice.
Table Wood Rectangle Beige Flooring
Wood Rectangle Flooring Floor Table
· Super Moderator
Discussion Starter · #12 ·
Moving along on the doorway. Showed the pic of the trim getting glued on. I put a cove on the inside edge and carved out the corners. Other side I'll pre-route the corners on the curve and straight pcs so I don't have to do that. I didn't know what I was going to do with the profile so I hadn't thought about it. But if I didn't to it that way it would have been really tough to clamp it on, so it worked out for me in the end. The other trim pc will be applied in the field after the door is in the RO.
After the glue up I worked on getting the angled members on. Had to move everything back to the way it was and level everything up good so nothing is tweaked. The floor isn't flat and it's an ongoing thing to make sure the woodwork is flat and true.
Used the CAD angles and they were spot on. The distance around the curve was perfect at 15". Pretty shocked it was so consistent. The side to side up top was shy on each side by a 32nd and down below was good at 15" again. Worked out really good. I had something tweaked when I went to put the outermost right angle board on. The inside box was out of square by 1/32". I can't imagine it tweaked it as much as it was though. So I did one side, undid it and did the other side and then put the screws back in and it all worked out. Measurements are good at 3 5/8" front and back so I'm happy.
Building Wood Table Stairs Wood stain
Just for fun I put the internal box together to see how it looks. I have to cut an angle cut on the outside corners of the curve miter and that will mate with the angle part that covers the box.
Wood Floor Hardwood Composite material Flooring
Have to put some kind of a sill inside the window bays and then some uprights to get the profiles of the window to line up with the door and miter and assemble the other curved trim pc and then it's onto making the 3 windows.
· Super Moderator
Discussion Starter · #13 ·
Couple of clamps
Automotive design Wood Mass production Table Engineering
Even on a ladder I'm having a tough time getting the whole thing in.
Wood Naval architecture Composite material Automotive exterior Water
Right leg
Wood Floor Gas Hardwood Composite material
Base.
Table Wood Floor Flooring Wood stain
Top.
Wood Hardwood Wood stain Tool Composite material
Intersection.
Property Table Wood Rectangle Floor
Now I have to figure out how I'm going to flip this thing over by myself and then I have to do the two angle wings and that'll complete the building of the entryway. Still have to mortise the hinges and make the windows and the stops to hold them in.
· Super Moderator
Discussion Starter · #14 ·
Apparently not out of my range for flipping over.
Wood Flooring Floor Beam Hardwood
Wood Shelving Ladder Building Shelf
Pretty impressed it stood up steady by itself. And it wasn't even tippy.
The bottom pic is the side I have some more work to do on. Clip the corners of the curved trim and then make the angled trim to connect the inside and outside together and glue it up. Hope I didn't forget anything.
· Super Moderator
Discussion Starter · #16 ·
Working on the curved window for the doorway. It's not like any other curved window I've made before. All of them have had a curved top that ends up being a half circle, ellipse or arch and the bottom leg is straight. So the stick cut goes onto the curve and the bottom leg is essentially with square ends for their copes.
This one has angled sides and a curve on the top and bottom. Racked my brain for a bit to get this to work but came up with the solution and then ended up modifying it when I was actually able to look at the parts and the jig for a much better outcome. My original plan had me destroying the pattern while the 2nd version wasn't a destructive cut.
I made my blanks for the curves and then put them onto my pattern of the actual size of the window.
Wood Flooring Floor Rectangle Wood stain
They are screwed from the rear into areas that will be cut off later on.
Wood Naval architecture Hardwood Composite material Natural material
Then as you can see in the above picture I have the pattern against my tablesaw fence with the wood parts facing down on the table. The fence is set up at 1 3/4" so it will remove 1 7/8" from the Oak. I need the curves to have 5/8" left over from the 2 1/2" from the side stile.
I pushed the boards through the saw and it left me this.
Wood Hardwood Beam Gas Wood stain
The nice part about it is I still have the pattern intact so if I need to do this again I can.
I put the copes on the ends of the "curves" still in their uncut forms and did a test and it took me a while to find where on the stile the parts go. It's very picky and will only work properly at the exact distance. The top and bottom of the window will measure about 14 15/16" all around. Took me about 10 minutes of moving things around to find that sweet spot.
Table Wood Rectangle Hardwood Plank
It's really hard to see in the picture but there are lines on the top and bottom parts that show the actual curve. The top part on the right you can see the best.
· Super Moderator
Discussion Starter · #17 ·
Got all the parts made. Now I have to figure out how I'm gonna glue this up. If I want to embarrass myself and use screws or do it the right way and just use clamps. The screws would never show, they'd be on the edge. But I'd know they were there LOL.
Wood Boats and boating--Equipment and supplies Natural material Wood stain Basket
· Super Moderator
Discussion Starter · #19 ·
Got it glued up. I used screws. But not "that way". I used them as clamp extenders. A trick I've used for decades when working with angles.
Wood Hardwood Wood stain Gas Automotive exterior
Wood Table Wood stain Hardwood Plank
While I was waiting for the window glue up to cure I started making the curved quarter round that will go into the top and bottom after the glass goes in.
Table Stairs Wood Beige Automotive tire
And here's the nearly finished window. Cut to size and fitted. Came out really well I think. Was worried about the straight copes meeting with the curved rails. Usually the mullion is only an inch or so wide. These are 3" including the beads, 2" on the flats. Can you see it? Sure, it's about 5-7 thousandths. I'll stick a bit of glue in there and sand over it and the sawdust will fill the "gap"
Wood Motor vehicle Automotive design Rim Engineering
1 - 20 of 44 Posts
