Canister Filter Cleanout
526 Views 18 Replies 8 Participants Last post by  DrRobert
I'm doing lots of work to my shop. I decided to blow ot my filter stack real good...I figured I'd share a before and after...
Before
Tableware Serveware Ingredient Coffee Cuisine
After
Wood Automotive tire Gas Rim Aircraft engine
I use a leaf blower outside while wearing a dust mask. It takes a surprisingly long time. I try to do a quick blow- down indoors whenever my shop is really clean, and I get it outside for a thorough cleaning every few months.
Reactions: 1
1 - 19 of 19 Posts
I remember doing that with my Wynn filter. Always a fun day making those clouds. I used my shop vac on the blower setting.
That's why I like the CleanStream pleated filters. I take them outside and hose them off until clean and then set it aside until it's dry. While one dries, a second one goes to work in the vac. No dust clouds.
My Delta has a flapper thingy inside that is rotated by a handle at the top. It doesn't clean thoroughly, but enough to knock off the fines and keep it going without a complete cleaning as you have done. I thought they were all made that way. I've used it for around 10 years and have never taken it off to clean it.
Reactions: 1
This is a canister not a shop vac filter. 😁
No cyclone I assume? How often does it require cleaning? That degree If clogging BC shows severely degrades performance.
Correct. No cyclone. As I said, I have never cleaned it to the extent the OP did. The flapper thingy removes most of the fines and keeps it from clogging like the pictures show. I just rotate the handle on top a couple of times every once in a while and continue working. I've never detected any significant performance degradation.
Yeah, this was as bad as I've gotten mine. Long cold winter I guess...I do own a cyclone... it's been sitting in my basement for about a year waiting on the shop upgrade.
Even with a cyclone the fines eventually cake up the filter. I don't think there's any avoiding it over time.
Reactions: 1
I use a garden hose to clean them and spares to let them dry
This is a 30" tall canister for a 2hp dust collector.
Do you take a garden hose to these? I would worry about rust and I am not sure the large canister filters are meant to withstand water.
Anyone have a source for "tall canister filters"? I'd like to have one clean and one in service. The filter on my Oneida is 18"x36". Priced it on their site it's like 540 bucks :O
I think he's talking about shop vac filters.
Thanks for that Doc. I checked their site last night, but they don't appear to have a filter with 18x36 dimensions. I purchased a filter from Wynn when I converted my old HF DC to a cyclone about 8 years ago.
No experance with large dust collectors, my dust collector is a shop vac
Engineering Gas Machine Electrical wiring Cylinder
see post no. 4
My two Jet 1100 were converted from bags to cannisters and from plastic collection bags to cardboard barrels at the time I bought them. First I spin the paddles to knock out most of the dust. And then since my shop is on the second floor, I carry the dusty cannisters carefully down the stairs to the driveway. There I roll them around and bounce them lightly on the ashphaly which does get out most of the caked on dust. Then I use the air hose from the outside on the vanes pushing the dust back inside. That seems to get almost all the dust to fall on the ground where I sweep it up into the tractor bucket and dump in the compost pile:
Liquid Fluid Plastic bottle Alcoholic beverage Gas
Wouldn‘t a cyclone alleviate all that? Is it a space issue?
Yes, and yes. I am totally out of floor space as it is now. That's entirely my own fault, however. I did experiment with Thein baffles and other internal "cyclones" inside the separator of the Jet, but nothing worked that well. I may have elaborated in the thread I linked above.
See posts 5 and 6 above.
Gee I wonder why 😂😂
Only two dust collectors?
Reactions: 1
1 - 19 of 19 Posts
