Dr. Robert, and anyone can answer - The PVA glue comment peaked my interest so had to look it up. If most white wood glue is PVA, what accounts for the various advertised holding bond? Surely Titebond 3 holds better than the Elmer's Glue school kids use.
Any comments on Titebond 1 (original), 2, and 3? Seems the newer stuff is more expensive. Are they really worth it?
The PVA glues all work about the same. There is a tendency to think white glue is weaker, but that's not true. I believe TB orginal is an aliphatic resin, TBII and white glues are PVA. White glue dries clear, so it is good to use with light colored wood. I've glued up lots of drawers with Elmers Glue All. It holds just as well as yellow glue!
TBIII is another animal completely. I think its a proprietary formula, but I know it isn't a PVA glue. I don't think it holds any better than a PVA. The main reason I use TBIII is the longer open time, so especially in the summer, I'm using it for panel glue ups.
Bottom line they all work about the same. I mainly use TBII.
Another thing to understand is whether a glue dries to a flexible or stiff line. This can be a consideration, for example when veneering or laminating for curves. Epoxy, urea resin and hide glues are rigid. PVA's, TB and TBIII will not.
While using a biscuit would be much easier, the rabbet I planned to use to join the 4" wide boards would be 3/8" D x 3" L. With those dimensions is it still called a rabbet or something else? My guess is three inches of long grain wood glued together with a PVA glue will hold, especially if that board is used to make up a panel with full length boards glued to it on either side.
Its not really a rabbet because its not accepting the end of a board. But I would call it a half lap. Yes it will hold quite well.
If PVA glue does not hold end joints well, will clear Gorilla (non-foaming) Glue be advised? If so, any drawback to using Gorilla Glue for the entire project?
The issue with end grain gluing has more to do with the wood than the glue. End grain tends to suck the glue up resulting in a starved joint. But not only that, there isn't a good substrate, or mating surface, such as long grain to long grain. Think of a board as a bunch of straws. The strongest joint will be long grain to long grain.
I have zero experience with urethane glues and I don't think they aren't commonly used in ww'ing. Far as I know they are not water based, there are issues with glue residue and quite messy deal with.
I agree with the saying you alluded to - There is never time to do a job right the first time but there is always time to do it over again. That is why I am here asking questions of woodworkers who know more than I do.
Titebond has quite a bit of info on their website comparing glues I recommend you take a look.
IMO good old TB original will take care of most any gluing.
