"Bucket" Size for a Super Dust Deputy?
6.1K views 11 replies 4 participants last post by  RepairmanJack
I have a very similar setup to your's. I have a 1HP collector with an add-on canister filter and the 4" super dust deputy. I use this for my smaller tools (miter saw, drill press & one router table). I have about a 20' run of 4" thin wall PVC pipe. I use automated iVac blast gates with tool power sensors and a controller to automatically open the gate for whatever tool I'm using and to turn on the dust collector.
I ended up purchasing the 4" super dust deputy kit off of amazon last year. It came with a 15 gallon drum which I've used up to this point. I've been doing some research lately trying to find a drum that isn't so tall so it will fit within the cabinet design I'm putting together. I've probably looked at many of the same posts that you've seen of people attaching it to 55 gallon drums or large garbage cans. I have yet to find one that shows effective CFM before and after that change.
I did find a larger drum option that Oneida has on their site. It's for a 35 gallon steel drum that's made specifically for the 4" super dust deputy. I was actually considering purchasing this unit because the height fit my cabinet design but when i saw the shipping fee was close to $100 I decided not to purchase it. Since Oneida sells a 35 gallon drum I'd assume you'd be safe to use up to that volume. If you want to go that large there are lots of 33 to 35 gallon plastic/rubber garbage cans that should work well for you.
I'll end up purchasing a smaller rubber/plastic container to use with the dust deputy. I plan on sticking at or under 20 gallons when I make this change but I also don't have any of my large chip producing tools hooked up to this setup like you do. I'm leaning towards something like this 20 gallon drum but I haven't made my final decision yet. I currently have this dust collector setup taken apart as I am insulating and prepping the walls for my cabinet installs. This week I plan on running power and starting to mount the PVC pipe. I think I'll have the dust collector up and running again in a few weeks so I can give you some better feedback then. If you setup something before then please let me know what you end up using and how it performs.
