I'm building a blanket box from 3/4 inch cherry.
Instead of rabbetting the corners, I want to create a vertical corner piece and dado the channel for the side and end panels. That will leave each corner with two dadoes with the panels at 90 degrees (obviously).
The trick is, how do I attach the vertical corner to the panels and not have the whole thing blow up when the panels expand perpendicular to the supports?
Thanks for any advice you can supply.
Darryl
Darryl
