1 - 20 of 26 Posts
Hi everyone,
I have a 40 inch by 1.5 inch piece of poplar, 3/8 inch thick.
I need to nail it on carpeting where the carpet meets hardwood floor. High traffic area.
Can I just shoot brads or should I use thicker finishing nails?
· Old Methane Gas Cloud
I would suggest using aluminum and screws. Cover the edge of the carpet, don't just abut against the carpet.
I think that there will be enough give in the carpet that any nail through the poplar and carpet will wiggle loose. Also, "High Traffic" and "Poplar" don't really go together.
· Old School
Wood has been used as thresholds and transition pieces as well as metals. If you have to use wood, you may want to pick a harder species. If it has to be Poplar, I would suggest finish nails with the tiny head. Use one as a drill. Cut off the head, and chuck in a drill and pilot the holes where needed. When nailing it down, use a nail set to seat the head. It will be less likely to split or crack the wood. Nail the piece uniformly, as you don't want it to be wavy by the nails varying in how tight they are seated. Both long edges should have a slight chamfer.
Thank you both.
It must be wood. I'll search for oak scrap and use it if I have it. I'll use the finishing nails as described and chamfer both ends.
About using a nail as a drill for the pilot holes: is that to ensure perfect diameter hole?
· Old School
Thank you both.
Yes, for the shank of the nail, and it keeps the wood from cracking and splitting.
I installed my poplar piece and two problems. Way too thin. I measured poorly. I need at least a 1/2 inch piece. Existing wood looks like oak and the poplar just matches poorly. Thirdly, some splits in a couple nail holes.
But the concept is excellent. I'll buy a piece of oak and redo.
Think I'll have a split problem with 1/2 inch oak?
· Banned
Using nails is like nailing through a face frame.
Most installers ill glue the strip down. It's usually looks similar to a T liquid nail is used between the carpet and the wood floor. The vertical piece of the tee fits between the wood nd carpet when you applied the liquid nail.
Discussion Starter · #12 ·
I'm not do a standard threshold. More of a repair. Our cats clawed the rug and shredded the ends. Need to cover up 2 inches of the carpet.
I'll search for a pre made oak threshold, maybe cheaper than a piece of oak. Can't be glued down, I'll try the finishing nails again.
· Schramm
There are a few companies that make a track and threshold system which works nicely which allow for a number of things that others do not. All methods will work but never nail through your threshold and make sure you have a threshold which is a transition from one room to the other and not a squared piece of wood.
Discussion Starter · #17 ·
OK, I made a new threshold from red oak. 41" x 2" by 1/2" thick. Stained it and it's drying. I'll use 2" finishing nails to nail it into plywood. I don't want to use too many nails or too few nails. Any advice here?
1 - 20 of 26 Posts
