1 - 9 of 9 Posts
Hi all, I was just wondering whether there was a way to make a simple wooden box, with a hinged lid, only thing is that i don't want to be able to see any part of the hinges at any point, I don't want to use anything like dovetail hinges because they can still be seen. Thanks, Ned
Turning Wood Into Art
welcome to the site Ned
you can try a pivot hinge. What size lid are you talking.
How can that be? Something has to be seen when the box is open.
a pivot in the side of the lid if the lid sits 'inside' the box can have a pin go into the sides and it would always be concealed.
It would have to be a spring loaded pin or the box assembled around the lid
Both pins would have to be spring loaded. There would have to be a substantial gap to allow for rotational clearance.
Reminds me of an alternate "pin" method for cabinet door hinges that I posted a while back...
http://www.woodworkingtalk.com/f27/fast-easy-cheap-hinges-18300/
Old Methane Gas Cloud
Just use nails as the pivot.
If the lid of the box is inset, during the assembly process use nails or brazing rods between the inset lid and the sides. They make great pivots and people will ask where is the hinge.
I did think that or dowel, nail should where less than timber dowel. depends on size of box and strength required. Hope OP comes back and gives us some feed back
1 - 9 of 9 Posts
