1 - 17 of 17 Posts
I was given a jointer, but the movers broke it.
I need to remove what's left of the blade guard, from this bolt - so I can build a new blade guard.
Any suggestions on how to do this?
No Longer Here, BY CHOICE
I believe the movers would just be purchasing me a new blade guard.:thumbsup:
Ouch, I can imagine the frustration. :furious:
I bet this is a press fit. Likely need to use a dremel type tools with small cutting blade to cut down to the steel screw, then hammer and chisel to try and break this off. I hope it comes off clean.
I would not remove it all
I would just cut enough away to get back to a round cap on the bolt. Then attach a flat plastic plate that's the same shape as the original guard using 2 threaded holes in the cap. It could be done pretty cleanly. You will have a difficult time attaching a new plate to the hex head shank of the bolt in my opinion. :yes:
That sounds like the easiest way.. I must ask: Are guards meant to protect me from shrapnel, or only to protect me from putting my hand in the blade? I ask, because that determines what material I can use.
The guard is to keep you out of the knives. The shrapnel or shavings are all shot out of the bottom of the machine. I havnt seen a hand thats been through a jointer but I dont think it would be pretty!
To keep your hands out of the blades
The thin metal or plastic on jointer guards will not keep flying metal parts within the unit...just my opinion. :no:
It is a guard, not a shield, it is meant to protect your hands from contacting the blade. Any replacement should be made with the same curvature as the original so no part of the blades are ever exposed past the edge of the material being fed through it.
Discussion Starter · #17 · (Edited)
I planned to use the broken one as a template, so it will have the same shape.
I didn't pay them, it was a volunteer thing. (friends)
You should just get the movers to replace it.
1 - 17 of 17 Posts
