I mentioned in another post about a chess board project. Thats actually a project I am just getting back to. I stopped because of the issues mentioned but can get it moving again. Thanks all.
Separately, I have a split rail fence coming down and want to use the wood for two projects. A shadow box picture frame (approx 26"x26" for a jersey) and a jewelry box.
The fence posts are black locust, 6ft long and about 5.5x3 They have two holes for the rails, but there are still good chunks of wood. I pulled one, cut it, not knowing what to expect after 20+ years in the ground.
Not an ounce of rot! Hard as rock, straight grain, no knots. A little tough to cut because of the hardness. It seems the part that was in the ground has more of a yellowish color, whereas the above ground part looks more like oak (in the meat of the wood, after cutting off the outside weathered layer). Not sure if its just coincidence on this one piece or there is a reason for it. Looks like it will be a nice overall color when finish is applied, though, as its a nice amber when I wet it.
I cut the bottom two inches off first and it seems this post was half of a branch/trunk because the bottom center of the post had the middle ring of grain. So, laying it flat, I could plain saw it or, if I put it on edge, quarter saw it. The plain sawn will give me wider boards but... less stable?
Im just at the planning/thinking things through stage.
So, first project here will be the shadow box. That should be pretty straightforward. I figure I could cut lengths quartersawn that are 26x2x3/4 for the frame as well as lengths for a hinged front to hold plexi. Aside from my general concern about warping this shouldnt be a problem.
The other project would be a jewelry box. Im thinking approx 8x12, 8 inches height. A few drawers, an opening top, standard stuff. It seems 1/2" thickness would be good for the sides of the box as this wood is hard
I guess Im just wondering any thoughts on using the black locust fence posts. I know they are hard and because of that, tough to cut. Would you worry too much about plain vs qs in this situation?
But its free wood. And I like the idea of using wood that is repurposed as opposed to purchased.
