Hi,
I'm new to the forum (just browsed in the past), and am hoping someone can help me out of the jam I've created.
I am installing door casing and am using a dual bevel compound miter saw. Based upon the passing recommendation of a friend, I decided to try beveling the miter cut on the legs to get a stealthier join. I had the saw set as follows:
Miter Angle: 45 degrees
Bevel: -10 degrees from 90
Kerf: 0.110
I set the bevel angle with a magnetic digital angle gauge.
Now, as I attempt to cut the head casing, I cannot match the angles. I have tried the complementary cut at 45 degree miter with +10 degree bevel and the fit isn't close. The finished edge of the head casing is far too "short" to match against the finished/facing edge of the leg.
Normally, I would scrap the materials and start from scratch, but these pieces are built-up, glued, and pre-finished, so I'd hate to lose the time (and money) I already have invested in them. I would be very grateful for any help you can provide. Thanks in advance.
Eric
Kerf: 0.110
Eric
