1 - 9 of 9 Posts
I would like to clear coat some garden tools I had to rescue from being outdoors for years. All clear wood now, I would like something oil-based and will keep them indoors when not in use.
The last time I did this I used a combination of an oil and a solvent, AFAICR, and it worked great, but can't now find my notes.
Thanks.
Don.
Thanks.
Don.
To keep it simple I'd probably apply a liberal application of Boiled Linseed Oil a couple of times or more a week or two apart. A paper towel applicator and burned when finished takes care of any fire hazards with a drying oil.
If you are good to keep them indoors when not in use I would use an gloss oil based polyurethane. I have the tendency to leave them outdoors so I use a gloss spar varnish. A gloss sheen is better to retard water in any finish.
Tung oil would apply the same as linseed oil. The big difference is the drying time between coats. It might take anywhere from a week to a month for a coat of real tung oil to dry enough for another coat. The way to tell when it's ready is to briskly rub the finish with a clean dry cloth and smell to see if the tung oil odor is on the rag. When there is no odor then it's dry. It's a pain but is a durable finish. It was originally used as a finish for the hull of boats.
1 - 9 of 9 Posts
