Ok, so I got my bench going together and it's 8 feet wide 32" deep with 2 layers instead of 3 as originally planned. I made the change to leave the top off of it for height concerns with a few 2 foot tall 3D printers. I left the extra height of the legs in case I want to make a simple enclosure for drafts at a later date. The 2 layers are made of 2 by 4's with 7 cross braces including the ends and are identical. Then a piece of 3/4 plywood and a piece of 3/8" BCX plywood on top of that. The whole back center will be 1/4" thick pegboard. It if pretty sturdy already but still needs bracing. What would be the best way to go about this? I thought of 1/2" plywood triangles with 2 on every corner at the intersection of the table tops. Or the regular angled braces on the short sides where the tall end faces opposite directions. Or the "X" where you notch out the centers. But what about the long back of the unit? Ideas?
Thanks,
Voltage
Thanks,
Voltage
