Hello everyone! I'm new to the forum and could use some advice on building my home bar. I decided to use cherry. I purchased a Chicago Bar rail in solid cherry. The Chicago rail is routed 2 times. One for a 3/4" bottom plywood, the other for a 3/4" top. My question: is it ok to use 3/4" laminated cherry plywood for the bar top or should it be solid cherry? I can't find solid cherry, but I can have it glued up by a cabinet shop. Someone from a lumber yard said for a bar top the 3/4" laminated plywood is more stable than the solid glued up cherry. Does this make sense? It is certainly cheaper to use the laminated ply but I just want to do the right thing. Either way I would put several coats of poly or epoxy on the surface to protect the top. Can someone please chime in with their expertise?
Thank you in advance!
Corey
Corey
