Hi, I am trying to decide how to modify my 14" Delta 28-245 bandsaw to improve dust collection. So far I've found three different approaches...
(a) I rejected cutting a hole in cast iron of lower wheel housing.... it would be nice to keep hose out of the way but I'm not willing to tweak the iron even though it seems to have worked for this guy
(b) My Plan B is to cut a hole in sheet metal over lower wheel.... which I might do, but looks like that isn't quite as good as I'd like
(c) Some people have claimed great success with various approaches to collecting dust right under the table. Some of those ideas allow for at least partial table-tilting.
I'm thinking about the under-table option, but am wondering if the speed & flow of air applied so close to the blade could cause the blade, even under tension, to be pulled a bit into a guide or bearing, causing premature wear? Has anyone played around with this or tried to measure blade tracking with and without the draw from DC mounted right under the table?
Thanks in advance
Thanks in advance
