1 - 12 of 12 Posts
So I have undertaken the task to build my wife and I a new bed. We know the look we are going for, but not sure how to go about putting it all together. The assembly of the head and foot boards should be simple, but what I am hung up on is the frame rails to the head and foot board.
We are both military so we will be moving regularly, which means the bed must be able to be taken apart into separate pieces (head, foot, side rails) and re-assembled at our next house.
What methods out there are suitable for this need and are within the reach of a novice woodworker? I'm just a hobbyist with a few basic tools (compound miter saw, circular saw, router, drill, but no jigsaw or table saw yet). Are there any ways to put a bed together that will suit my requirement? I looked into the "bed bolt" joint and it looks a little more technical than my abilities allow. My wife had suggested just getting a metal bed frame and attaching the boards to all sides but I want to do this 100% myself if I can, not just slapping a facade on a cheapo frame
Does Seymour Johnson still have an open wood hobby shop? If so that would be a good place to use a table saw and get same assistance from the shop keeper.
+1. :yes: Or Pope...if it's more convenient, and if they have a shop. An Army base like Ft. Bragg might offer the use of one if it's offered to military in general...like PX's and BX's.
Your local HomeDepot will also carry the hardware for bed frame assembly. A router or some chisel work is needed but not difficult. I saw them locally and believe cost was about 18$ or abouts. Good luck.
As of a year ago when I left Fort Bragg, Pope Army Airfield (as its now called) had a woodshop. You had to take a shop safety course and I think there was a nominal fee for use. They had a couple 2-3 nice Powermatic cabinet saws with Biesemeyer fences, a couple of planers, and I think 2 8" jointers with 6' beds on them if memory serves me correctly.
Discussion Starter · #10 ·
I'll check out SJAFB to see if we still have the wood shop.
I found plenty of places for the hardware, but it seems like most of the hardware is joint-specific. I was looking more for which technique would be best or if there are any to steer away from.
These two I found looked good, wasn't sure how sturdy it will be.
http://www.woodcraft.com/product/2003269/3200/bed-rail-fastener.aspx
http://www.woodcraft.com/product/2081356/30375/woodriver-bed-rail-bracket-set.aspx
I plan to build the actual bed frame itself from 1x10 Red Oak side rails with pine cross beams to save on cost spacing them every 10 inches. It needs to be very sturdy since we'll be putting a memory foam mattress on top (those things aren't light!).
The first one looks sturdy enough but I would have to educate myself on how to properly install them. The second set looks simpler with just one countersunk hole needed but with that one screw holding it all together I worry about flex.
I've dealt with this junky Ikea bed for a long time. Its not horrible but you can tell when you get in there is plenty of sway and its rather disconcerting. Ultimately I want something that wont feel like you're boarding a small boat. There was a non-mortise option but I fear that will just be too unstable. But the two I linked seem sturdy and simpler than bed bolt joints.
1 - 12 of 12 Posts
