Typically I work with 3/4" thick to 1.5" thick aprons where I would Use standard M&T construction with corner reinforcement or brace. However, I'm making some small cabinets for the family where the side apron and front apron join and the apron will be only 1/2" thick because of the cabinets small scale. It cold be thicker, but it seems out of proportion. My concern is the joinery for each corner, I don't feel comfortable to M&T the corner joints with the connection members only 1/2" thick. SO I have considered a butt miter with a splice. I tried a double lock miter, but still too thin of material. I made sample joint using dovetail construction, although certainly possible, the family did not care for the appearance. (!) So at the present I'm looking at either a mitered butt splice or a butt splice with a miter and corner brace. If you have any suggestions, I would appreciate hearing your thoughts.
