Hi everyone. I'm in need of some help. I have inherited an old butcher block from the mid-1800s that was in use in our family store generations ago. (photo attached) Until about ten years ago, it was in use on our family farm. It's a single piece of wood (tree cross section), and the top has been waxed with paraffin and rewaxed with paraffin for generations. As far as I can tell, the bottom was never finished. As a result, it has a large number of cracks, but the top only has two cracks. Both run in the direction of the rings and go all the way through the piece.
Here's the problem. I want to use it as a coffee table, but it's rather nasty looking at the moment. After all, it's got 150 years of animal fluids and wax as a finish. I want to try to take off the top 1/4 inch of wood to remove a warp, and get back to a point where I can see the rings. At the moment, it's solid brown with zero underlying wood grain showing through.
I can plane it with the router, but I fear it might blow apart. I can plane it by hand, but there's so much wax, that I'm not sure how I'd get down to the wood without spending 20 hours cleaning paraffin out of the blade. I've thought about filling the cracks on the bottom with epoxy to lock the thing in place, but I don't know if that will do the trick or not. I also have no idea how to finish something this old. Again, I don't see it ever being used as a butcher block again, so I'm not concerned about food-prep.
To sum up:
1) would the epoxy help me keep it from splitting more (not as a finish, just as a void-filler/glue?
2) how would you go about getting rid of the wax, or do I even need to?
3) chances of it blowing apart if I try to take very small bites with a router/sled plane?
4) what else am i not thinking of?
Any tips would be appreciated.
To sum up:
