1 - 6 of 6 Posts
I have been recruted to build my brouther in law 5-6 shelvs After sanding the amber shalac off 3 times :censored: due to runs on the edges I am getting frusterated.:furious: If their are some tips you you know PLEASE feel free to leave them.
What I like to do is cut the 2 pound mix from the can 50/50 with denatured alcohol. Then I just wipe it on with a folded up rag, and wipe off the excess. Once it dries, I'll lightly sand the surface, then add onther coat or two.
Discussion Starter #3
I have been using a brush at full strength so far. What grit should I sand with?
220-320g
span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
Discussion Starter #5
ok going to try it tomarrrow wish me luck.
Discussion Starter #6
I sanded down the runs in one peice and tried to use the 50/50 to do a touchup with little sucess. on one peice that i had not started iit was EASY to do with no runs at all thanks a ton. i have 1 more to sand down and redo. Thanks.
1 - 6 of 6 Posts
