Check the information here. Might not be definitive but should be close enough.
Sears | Craftsman - Photo Index | VintageMachinery.org
thank you so much!!!It appears the 113.23100 is from the mid to late 1970's, haven't seen a listing for the 113.196321 but a 113.196320 is listed as from 1993.
I would take a good look at the condition of both saws, if the older model is in better condition then it may be wise to hang on to it.
Chech out the recall model numbers to see if either fall into that category as well.
thank you! Good insight.Sears really value engineered their saws badly as time went on. They got worse and worse. So the older saw may be the better saw.
BUT as others have said it is all about condition. A heavily used saw maybe have sloppy slides and not be able to make good quality cuts. I was given two and got rid ot both because they were junk.
I love my molding head, I've got the three blade one and I have done door moldings, baseboards and trim with it and this last year I bought a feeder and started making rail and stile cabinet doors with it. There's a thread on this forum somewhere showing how I built the fences and sleds to turn the RAS into a molder/shaper.One thing I don't recommend though is using a molding head on it, too dangerous IMO.
