I use them quite often. My arsenal of tools includes both traditional and carbide. Each tool material has it's place, it's pros and cons. Often I will find I use both on the same project. Other times I may turn an entire project with a traditional bowl gouge and finish scraper.i have access to some redgum but spend a lot of time sharpening tools anybody tried tunsten tools
as iam thinking of getting same.
thanks for the reply dave i have sent for tools todayI use them quite often. My arsenal of tools includes both traditional and carbide. Each tool material has it's place, it's pros and cons. Often I will find I use both on the same project. Other times I may turn an entire project with a traditional bowl gouge and finish scraper.
I would certainly NOT discourage anyone from adding a set of carbides to their tool selection.
thanks for the advise i am in australia and not able to try arizonaFor others:
The OP is asking about turning tools for woodturning on a lathe. There are two popular types. One type is High Speed Steel ("HSS" or "traditional") which must be sharpened frequently using a grinding wheel or sanding belt. Professionals often choose them. The other type is Carbide tipped, which have small replaceable tips of tungsten carbide. To sharpen, you rotate the tip to expose a newly sharpened edge or replace the tip when it is used up. You can sharpen them yourself on a diamond stone.
My response to @wood worm:
Like @Dave McCann, I use both types. I prefer the traditional types, but some days the carbide tipped ones do better, or I am lazy about sharpening.
If you have never turned with carbide tipped turning tools and you have a chance, give them a try. You don't have to pay manufacturer's prices for replacement tips. There are third-party providers who offer quality replacement carbide tips at a reasonable price. Try Arizona Carbide, for example.
I too started turning in the 1960's. And I have and use carbon steel, HSS, tantung and carbide tools. Carbide are my least favorite, although I understand some makers now have better edges on the inserts so they cut like traditional tools. When you want a really fine smooth cut, sharp carbon steel still can't be beat. too many turners have the bad habit of using HSS cutting tools as scrapers. I still use my skew to scrape sometimes and the difference in the resulting surface is quite apparent. I use carbide blades on my table saw because of the smooth cut they make. Saw blades have carbide tips engineered specifically for cutting wood at a proper angle. Carbide turning tools are just now being developed and engineered for slicing wood instead of scraping like the tools have been used for the last 30 years. We both have seen remarkable differences in the tools and accessories used in wood turning. There are still improvements hitting the market. Standard carbide tools haven't yet been developed to match traditional tools.To me, carbide turning tools is like carbide saw blades: who uses steel circular saw blades anymore when carbide works better in most cases? No, I'm not saying to get rid of your non-carbide turning tools, rather supplement them with carbide. I don't think you can get all the crisp details with carbide in some cases that you can with HSS but that's just an opinion on my part. Then again you can take off a lot of wood with carbide and not have to continually sharpen your tools like you do with HSS. Use each for what its best traits are and benefit from both type of tools, and they each do have things that they do better with than the other does.
I started turning back in the 60's and I have carbon steel, HSS and now carbide and I use them all. Each has a particular use, it's up to you to determine which tool work best in each situation and leverage those advantages.
My 2 cents.
What size (mm) do they measure? The link you provided did not give an actual measurement.My one mistake was not thinking about replacement tips. My set of 3 tools/one handle is from Harrison Specialties and their tips seem to be an unusual size.
90 degree carbide square cutterWhat size (mm) do they measure? The link you provided did not give an actual measurement.
I've had good results buying in boxes of ten from Ebay sellers.90 degree carbide square cutter
Corners are very sharp with no radius.
Size: 14mm x 14mm.
This round insert does indeed seem to be an odd ball size.Replacement Round Carbide cutter for Simple Turner & Hollower (STH)
Specifications:
- 9/16" outside diameter [converts to 14.2875 mm]
Yes it is, and that is the one I need more than the square. And the replacement tips from Simple Turning Tools are $16.50 ea or $33-36 for 3 pack of all same or assorted.I've had good results buying in boxes of ten from Ebay sellers.
