They come in 4x8 sheets.
They come in 4x8 sheets.Is your rigid foal the same size as the top or is it bigger?
The retractable wheels do no have locks because when the wheels are retracted (flipped upward against the leg), the legs sit directly on the floor. My shop is an old rental facility with dips in the concrete floor and the tables hardly ever sit flat on 4 legs. Under the bottom part of each leg i put adjustable/leveling feet so the table /bench rests solidly on the floor.Thanks for the note on the wheels. So your wheels are retractable and have locks? Do you remember which you used? They sound good. Do you only use your table saw to breakdown sheets or do you also use a track saw? Just trying to gauge if your size tables work for a whole sheet when using a tracksaw.
Are you guys using 3/4" ply for the top or is anyone using MDF or something else?
Another thing that just occurred to me is if I do integrate the table saw, I am thinking I may need to cut slots into the top by the table saw so sleds can be used. Never thought about that until now. Or maybe I am missing something.
Yes cutting the sheets down is a good idea. I never did that but should have. I would do [email protected] 4x4I have often thought about using the rigid sheets for cutting platform but then I have to store it somewhere. I thought about ripping it into 2 x 2x8 pieces in attempt to make storage easier. I would prefer to be able to go without it but its an option. I was hoping to be able to use something like bench cookies to prop up the sheet for cutting, but that is where my concern for the top dimensions comes in. If I used bench cookies then I am not 100% sure how much overhang is ok when breaking down a sheet so that pieces wouldn't be falling off or whatever.
At this point, I am thinking width needs to be at least 3' wide. The length I am still unsure about. If I do integrate the table saw then that will add about 2' to whatever table/bench length I go with. So a 6' table/bench added to the ~2' for the table saw portion would make ~8' as a total surface with 6' as outfeed. Still playing around with these dimensions to maximize usability and taking minimal footprint.
My fence will extend on either side and the max is to the right at 36". I don't think I would ever have the need to crosscut a super long piece like that. I would use my miter saw instead. Up until this point, I have only used the tracksaw to break down sheet goods and that would probably remain the case unless my workflow changed when I get some kind of solution built from this.Yes cutting the sheets down is a good idea. I never did that but should have. I would do [email protected] 4x4
THE only reason I bought a track saw was I couldn’t wrestle sheets anymore b/c of my back. Plus long rips on table saw takes some technique, and unless you have a rock solid fence, you’re going to get some flex and an inaccurate cut. That’s where I question the compact saws, but maybe the DW locks up good.
I don’t think you need 6’. Mine is 48”. All you need is about 5’ past blade (including saw) to keep 8’ from tipping.
Where you’re going to have an issue is width, am I right? What is the maximum extension of the fence? Another example: Let’s say you’ve ripped a book case to 12” now you need to make them 84” high. How are you going to cross it them? Table saw maybe a big sled and clamp the boards? Maybe a miter saw? Sure, but I suggest this is another place a track saw prevails. Gang them up and cut together. 😁
I would take double up mdf over one sheet of plywood any day. Add some polyurethane to the mdf and it becomes incredibly tough.Yeah I've been thinking about it. I think 3/4" will be plenty strong for my use and at ~$100/sheet for hardwood plywood I really like 1 sheet lol. But again I don't want to have to do this twice so I'll think about doubling it. I do plan to put in some T-Track because I have always wanted a flat surface with T-Track. So if I did double the top and then put a shelf on the bottom, I will probably need 3 sheets, so $300+ just for plywood. SMH. Shouldn't be this expensive for a work bench lol.
Particle board would be much more rigid than MDF and cheaper. That being said I would still use plywood..I would take double up mdf over one sheet of plywood any day. Add some polyurethane to the mdf and it becomes incredibly tough.
