So I turned what could either be called a deep plate or a bowl depending upon which angle you view it from. It's about 11" diameter and 2" deep and I went thin wall with it without thinking about the fact that it's yellow poplar.
It looks nice, but feels like it belongs in an arts and crafts store for $1 as something for kids to paint, cover in glitter, and write "ЯonNy Agɘ 5" on the back b/c it's light, soft, and with your eyes closed you might mistake it for paper mache.
I don't have the necessary equipment to stabilize wood using vacuum pressure, although I hope to eventually. What are other options? I don't mind changing the color - I'm not a fan of yellow poplar anyways. I got the blank for practically nothing since it had warped while drying.
Edit 1: I found a tutorial by forum member BangleGuy that includes, from what I understand, soaking the wood in TurnTex Cactus Juice and then baking it as a stabilizing method. What I don't know is whether that would add strength and weight like I'd like.
Edit 2: Read the directions for Cactus Juice. It unfortunately requires a vacuum pump.
Edit 3: Interesting thread on penturners.org about stabilizing without vacuum pressure.
