The motor on my old craftsman lathe bound up on me last week. I thought this would be a good time to try and swap to an DC motor so I can have a variable speed motor. I've heard it's common to use a treadmill since it already has the AC to DC converter, motor, and speed controller. Has anyone here done this swap? I have a buddy that has a treadmill he's going to give me for this, but I want to get as much info on the swap before I start tearing into it.
DC conversion
This might not be worth it, but you can get an AC VFD for your lathe. AutomationDirect.com sells a 1/2HP VFD for less than $120. You need a 3phase AC motor, but if you can scrounge one, worth it from my experience.
Not sure if you have or haven't done this yet since this is an older post(and I don't get on here as often as I should), however I just did the treadmill conversion to my Shopsmith in January.
It went very well, I was able to find a treadmill for free that had a 1.5hp DC motor in it. I stripped the entire treadmill of its components and basically all I did was shorten up the wiring and move the components to a different box. I left the flywheel on the motor and decided to use it for my pulley. I clamped the motor to my bench, hooked all the wiring up and turned it on and ran it slow while I took a bastard file and cut a groove into the pulley. It took a little while, maybe 30 min or so to get it where I wanted it. The control board had 4 POT adjustments on it, 2 were for speed(low and high end) the others I figured out were for torque and governor response to a load.
Overall I have to say that I love the results, especially considering the conversion cost me a whole $15. I have the speed range set from roughly 100rpm -3000rpm with good response to loads. I have another old Shopsmith that is waiting for its overhaul and I will be doing the same conversion to that one as well. I have only 1 complaint, and that is it has a built in time delay on start up. Turn it on and count to 5 then it starts nice and slow. Not really much of a pain just takes some getting used to.
The gray box with the dial is my control box.
Discussion Starter #4
Thanks for the reply! Your the first person I've been able to find that has done this to their lathe. I haven't had time to do the swap yet since I've had to much to do on the house and other projects. Hopefully I'll be able to work on it soon.
Back on Woodcentral several years ago there was a discussion about using treadmill motors. You might be able to do a search there and find the info. www.woodcentral.com go to the turning messageboard.
There was also a way to bypass the slow start function. I bought 3 of the motors and controllers but was only successful in getting one of them to work. I had controller problems with the other 2 and have never been able to even get the motors to work.
If you use one straight from the machine without modification It should work fine.
