I have a Ryobi BS901 I bought used and have found to be good... with the 1/4" blade. But I just burned up a whole lot of time, braincells and patience trying to get a 1/8" blade to track. THEN I see in the manual an add-on note that says that the 1/8" blade may not track well in the middle and should be set to the back of the upper wheel. So, good enough, but I cannot even get it to do that. Any adjustment, when it finally kicks in, throws the blade to the other side quickly and I can't make it happen.
I have a Griz 17" and I do have a 1/8" blade for it but one of the reasons to have a smaller saw is to do finer work, right? As it happens, I wanted to cut some aluminum and thought that should be a quick job.
Now, I'm pretty much done. I've tended to buy used or inexpensive tools until I find a reason to do otherwise. I'm now ready to buy a better small bandsaw and I'm asking for suggestions and recommendations.
Thanks all, for putting up with this rant. If you read to the end, you should get a medal of honor or something!
Chuck Barnett
Chuck Barnett
