I am planning to build a work bench with a 96" or 108" x 48" laminated maple top of at least 2" and can't find any available. Suggestions?
I have a 4x8 bench in my paint department with a 3/4" plywood top I use for mixing paint. I have another one with a 3/4" plywood top covered with carpet for sanding. I have another that is made from 2x12 yellow pine glued up that is an assembly table and doubles as a cold press for veneer. Then I have this one that has a 4x6 top that is 2" thick ash top I use for woodcarving.Wow! That is going to be a really large workbench. Are you using this for assembly or as an actual woodworking bench? The reason I ask is because at 4' deep, you will be doing a lot of walking around. Only you know what you need and what you will do with the bench, but if you look at so many of the workbenches over the centuries, they were only about 2' wide because that is the average man's arm length. Just food for thought![]()
Each to there own. I can tell that by your post you are not the typical hobbyist (paint department)I have a 4x8 bench in my paint department with a 3/4" plywood top I use for mixing paint. I have another one with a 3/4" plywood top covered with carpet for sanding. I have another that is made from 2x12 yellow pine glued up that is an assembly table and doubles as a cold press for veneer. Then I have this one that has a 4x6 top that is 2" thick ash top I use for woodcarving.
