1982 Delta/Rockwell 14" band saw.
1/2 hp motor.
Original stand on casters.
Tires have cracks will need replacing sometime in the future ($30) The blade tracks perfectly now, and saws great.
Saw has a non orig. upper guide assembly, that used the same side guides, but a larger thrust bearing. This guide assembly allows an extra inch of resaw!
The guide post is a hex post. Or if you want I would sell it with a round guide post, that is for a saw with a riser. This saw doesn't have a riser.
All my old blades are included.
I took the riser off this saw for my saw, and if the guides would have fit the hex post I bought for the riser, I would have used it.
$325 Located in Englewood, FL
1/2 hp motor.
