Any ideas how to make a 1/16th inch dowel?
Any light color wood will be fine, they need to be about 6 or 8 inches long and I will need two of them.How many do you need? What type of wood?
I was about to suggest those bamboo skewers myself!Fat cocktail toothpicks if they don't need to be too long.
I've discovered that bamboo satay skewers come in all sorts of diameters, right up to cheap chop sticks.
They have been wonderful as glue pegs in short lengths. Bet bet is a kitchen store.
Meaning you used a power planer knife hand held as a fro and then as a scraper?I split the planks and smoothed them with a planer knife.
half of what ? sorry - I can't see anything - can you draw a yellow circle around it ?the thinnest of the dowel pegs you see. I didn't realize this stuff was meant for veneer.
My planer knives are dogleg diamond willow with a double edged PacNW blade hafted.
The whipping hides all the hand grime. After I split cedar, I need to get it smooth enough for drawings.
I don't have a picture of a whole one. there's about 1/2 at the bottom edge here.
BigJim: Any ideas how to make a 1/16th inch dowel?
Thanks Ken and thank you J L, those are great suggestions I really appreciate it.View attachment 428877
and this is how I did it - - - -
Remembering that I had a 1/8" Birch Dowel on hand, I used the electrician's wire strippers to get started.
the 4th hole was exactly 1/16" on my tool. (yours may vary).
with the bench vice open 1/4", I started pulling the dowel through the largest hole and progressively moved on to the next smaller hole. the 1/16th hole was a bit tricky as the wood got really small. after the dowel slid through the desired hole with little resistance, I smoothed off the fuzz with sandpaper and now I have a 18" perfectly uniform dowel that is 1/16" from one end to the other. took all of 10-15 minutes.
Jim - do you need this Overnight Express or will Snail Mail do ??
